14 years ago64bit works. However, word has always been that 64 bit performance is not as good as 32bit, and only necessary with devices that need the larger RAM support.
So, the work around is to generate the part in the 64bit IDE wizard, then build out of 32bit. Not exactly direct, but it works. Wish Altera would fix the 32 bit version.
