Qsys update
Hi
I have a big qsys file (platform designer) Quartus Pro 19.4. I migrated successfully to 20.3.
I tried migrating from 20.3 to 20.4 I get this error:
Info: E:/Buildscript/LPUX274_20_4/src/qsys/ip/**/* matched 39 files in 0.08 seconds
Error: Factory com.altera.sopcfactories.QsysFactory reading E:\Buildscript\LPUX274_20_4\src\qsys\qsys.qsys exception com.altera.utilities.altNode.AltNodeException: (in-memory string): Invalid byte 3 of 3-byte UTF-8 sequence. (XML)
Hi Ben,
I have sent an email to you. Please help to check.
Shyan Yew
- RichardT_altera
Hi Ben,
Shyan Yew
- Ben_C
Hi Shyan
Your Quartus update resolved the error
Thank you!
Best regards
Ben
- RichardT_altera
Hi Ben,
I am happy to hear that!
For those who might come across this issue, please upgrade your Quartus Pro to version 21.1 once it is available to download. This issue is expected to be fixed in v21.1.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Shyan Yew (Richard)
- RichardT_altera
I haven't see this error before.
Which OS that you are using? Have you try to clean and rebuild your project?Could you help to share your design so we could check on this?
- Ben_C
- SLabe
@RichardTanSY_Altera , I emailed you the Qsys. Good day and thank you,
- RichardT_altera
I tried to open the qsys.qsys file that you provided.
Unfortunately I don't see the error message pop up, other than the warning messages pop up saying a lot of IP files missing.
Have you try to uninstall/reinstall the Quartus and try to migrate the project again?
- RichardT_altera
Finally, I am able to duplicate the error in Window 10 platform. Previously I did it in Linux platform thus showing different result.
I will check with our engineering team for further investigation.
- RichardT_altera
May I know how do you migrate the previous qsys.qsys file version 20.3 to 20.4?
When I open the previous qsys file 20.3 in the Quartus 20.4 in Window 10, there is no error produced.- Ben_C
1)open quartus project
2)open qsys.qsys (no errors)
3) Sync System infos
4) save (same xml error occurred while saving)
With GIT, I can see all my IPs are now 20.4 instead of 20.3 and qsys has many changes
5)Close qsys
6) Reverted qsys.qsys
7) Open qsys.qsys
Click validate system integrity 9) Save (same xml error occurred while saving)
