I have the same Problem with .bsf generation in QSYS v.12.1sp1 ...
I had a .bsf built with QSYS v.11.1sp2, which looked quit usable
After compilation with 12.1sp1 everything was scrambled :mad:
The old 11.1-bsf begins with
(header "symbol" (version "1.2"))
(symbol
(rect 64 64 384 1512)
(text "fpga_backup" (rect 148 -1 234 15)(font "Arial" (font_size 10)))
(text "inst" (rect 8 1432 25 1444)(font "Arial" ))
(port
(pt 0 72)
(input)
(text "clk_clk" (rect 0 0 37 14)(font "Arial" (font_size 8)))
(text "clk_clk" (rect 4 61 41 75)(font "Arial" (font_size 8)))
(line (pt 0 72)(pt 128 72))
(port
The new one (v12.1) begins with
(header "symbol" (version "1.1"))
(symbol
(rect 0 0 512 1448)
(text "fpga" (rect 244 -1 261 11)(font "Arial" (font_size 10)))
(text "inst" (rect 8 1432 20 1444)(font "Arial" ))
(port
(pt 0 72)
(input)
(text "in_port_to_the_data_link_irq" (rect 0 0 113 12)(font "Arial" (font_size 8)))
(text "in_port_to_the_data_link_irq" (rect 4 61 172 72)(font "Arial" (font_size 8)))
(line (pt 0 72)(pt 224 72)(line_width 1))
Is it possible that QSYSv12.1 uses an older bsf-generator ???
The bsf-syntax seems to be quite simple, so it shouldn't be a big issue to build a TCL-script,
which makes a .bsf looking like the good old SOPC-symbols :-)
I haven't found a documentation of the .bsf syntax so far. So I tried to comment my
automatically generated one....
(symbol
(rect x1 y1 x2 y2) --> the rectangle for the symbol
(text "<title>" (rect ....)(font "...")) --> Title of the QSYS-System
(port
(pt x y) --> coordiates of the connection point
(input)
(text "...." (rect 0 0 x y)(font "...")) --> ?? ist it the signal name of the port
(text "...." (rect x1 y1 x2 y2)(font "...")) --> Text which appears as node name
(line (pt x1 y1)(pt x2 y2)(line_width 3) --> line to the port (Bus has line_width 3)
(port
maybe I've to play around a bit...
... but maybe somebody already has done it :)
