12 years agoNot quite what you're looking for, but the SOPC Builder "version 1.1" format is produced by the Perl script in sopc_builder/bin/mk_bsf.pm Yes it looks pretty simple.
An alternate way to work around this problem is to use Quartus to produce your own .bsf file from a modified copy of your Qsys top-level .v or .vhdl file. In other words, create a copy of the top-level HDL file, modify the ordering of the ports, and then use Quartus File->Create/Update->Create Symbol for Current File... to have Quartus parse and generate a new .bsf from your modified file. You would only have to repeat this process each time you change the ports included in the top level Qsys.
