qsys-generate outputs Info as Error
From what I understand, the Quartus is supported in Microsoft Azure Platform.
https://docs.altera.com/r/docs/683498/17.1/quick-start-guide-for-development-tools-on-the-microsoft-azure-platform/setting-up-an-intel-quartus-prime-project
Correct me if I am wrong, it seem that Azure DevOps / TFS and Microsoft Azure Platform are related but not the same thing.
https://www.knowledgehut.com/blog/cloud-computing/azure-vs-azure-devops
If that is the case, the Quartus is not officially supported using the Azure DevOps / TFS.
Richard Tan
Hi Richard, thank you!
But as far as I unterstand this error, it should not be platform-dependend or -triggered. Each console running qsys-generate should see this "Info: Parallel IP Generation is enabled." as an error. Or am I wrong?
