14 years agoQsys-DDR2_SDRAM Configuration
I´m new in the IP Core design. I`m using a Cyclone III 3C120 Development Board and now I want to design an IP Core with the following parts: clock source, Nios II Processor, Character LCD, PIO, On-Chip-Memory, DDR2 SDRAM Controller with ALTEMEMPHY. My problem now is: If I choose the DDR2 SDRAM a Warning appear. Warning: System.altmemddr_0: Cyclone III speed grade 7 does not support DDR2 SDRAM operation above 167.0MHz. In my understanding I just say, that I can´t drive this SDRAM over a frequency of 167MHz. So my question is: Should I change the configuration of the memory? And if I need to do this, how can I do it? And which things do I need to change and where I can find them? Thanks for your reply!
