Qsys custom component generation callback issue
I have a few custom Qsys components where I generate the final VHDL source to be included from a template file using the generation callback. The generation consists of omitting input and output port signals., e.g. remove the channel info from the stream. Now if I use a component multiple times in a Qsys set-up, the generation will produce sub-module files where the previously generated source precedes the actual generated code. So if e.g. I use the component three times, the first generate file holds a single entity, the second will get two entities, and the third three (and so on ...). You can see the effect in the attached files. I also attach the hw.tcl file for the experts. The attached image shows that the generation writes the same amount of lines for both instances, yet for the second instance the result shows that it is a concatenation of the previous one with the actually generated.
