11 years ago
QSYS closes without ERRORs
I'm using the latest Quartus II Subscription Edition and Qsys closes without warnings or errors when opening a qsys-project with the [Altera PLL] inside, like the [bts_ddr3_hard] example or when adding it to a new project. When the PLL is attached in the Quartus Software, outside of the Qsys, everything works fine.
One of my co-workers removed the pll from the example and i could open it, so im sure this error happens cause of this IP-Core. Are there any solutions for this bug?
Thank you for considering my request.
1 Reply
    I have to correct myself. After extensive testing I can say that the pll is the only ip core that shows this behavior. And, I didnt expected this cause there was no error during the compile, I also cant add the [altera pll] ip core to a Quartus project. A small window appears [loading MegaWizzard...] and, while for all other ip-cores I can now config the Core, nothing happens when I try this with the altera pll. So this is, for me, not only a Qsys Bug.
    I testet this with Version 14.0.0 and 14.0.2
    Do i have to set an extra environment variable for this core / the MegaWizzard or is there a Log-File that could help to locate the error?
