Qsim Windows
I have installed Quartus Prime Lite Version 18.1, and I want to simulate the design using Qsim. How can I install Qsim or is it already available in Quartus?
- RichardT_altera
Unfortunately, qsim is not supported and has been replaced with Simulation Waveform Editor (Go to File>New>University Program VWF).
I recommend that you download and use ModelSim-Intel FPGA Starter Edition for simulation.
https://fpgasoftware.intel.com/?edition=lite
p.s. Don’t forget to Reply, and Select the Best Solution. :)
- PSriv8
Thank you for your reply. I want to perform the synthesis of a digital circuit to calculate its area/delay/power. I have downloaded a pdf regarding Qsim and I have got an impression that it can calculate the processing time required by a digital circuit. I do not know if Simulation Waveform Editor or Modelsim can calculate the processing time of a circuit.
For example: I have a 2x1 mux and I need to calculate the time taken by mux to provide output once I change the input. I know that I can calculate the processing time using Synopsis/Cadence software, but I was wondering if Altera Quartus software can also do the same?
- RichardT_altera
> You can do that with power analyzer tool though I am not expert in that tool.
Reference: https://www.intel.com/content/www/us/en/programmable/documentation/xhv1529966780595.html
> You can perform timing simulation with Simulation waveform editor, in which the logical functionality of the design is tested in the presence of delays in order to observe the actual propagation delays in our circuit.
