BCuze's avatar
BCuze
4 months ago
Q pro 26.1 Netlist Viewer crash
Note : the reporting system seems to still point to Intel...
Quartus Pro 26.1 Crash
Problem Details
Error:
Internal Error: Sub-system: NLWQ, File: /quartus/gcl/nlwq/nlwq_view.cpp, Line: 270
show: bad page number 2
Stack Trace:
Quartus 0x30405e: NLWQ_VIEW::execute_command_line + 0x3e (gcl_nlwq)
Quartus 0x47873: NUIQ_VIEW::change_page + 0xb3 (nlv_nuiq)
Quartus 0xe755: NUIQ_VIEW::qt_static_metacall + 0x285 (nlv_nuiq)
Quartus 0xdfa42: QObject::qt_static_metacall + 0x14c2 (Qt6Core)
Quartus 0xe2463: QMetaObject::activate + 0x83 (Qt6Core)
Quartus 0x20e0: NUIQ_PAGE_TOOLBAR::qt_static_metacall + 0x60 (nlv_nuiq)
Quartus 0x1383da: QComboBox::editTextChanged + 0x80a (Qt6Widgets)
Quartus 0x1400ca: QComboBox::setCurrentIndex + 0x43a (Qt6Widgets)
Quartus 0x13c2a9: QComboBox::itemIcon + 0x289 (Qt6Widgets)
Quartus 0x13a9d3: QComboBox::iconSize + 0x413 (Qt6Widgets)
Quartus 0xdf9d7: QObject::qt_static_metacall + 0x1457 (Qt6Core)
Quartus 0x138ecb: QComboBoxPrivateContainer::eventFilter + 0x50b (Qt6Widgets)
Quartus 0xa4f06: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0xd6 (Qt6Core)
Quartus 0x12f36: QApplicationPrivate::notify_helper + 0x136 (Qt6Widgets)
Quartus 0x110bd: QApplication::notify + 0x6ad (Qt6Widgets)
Quartus 0xa23ce: QCoreApplication::notifyInternal2 + 0x10e (Qt6Core)
Quartus 0x15dd6: QApplicationPrivate::sendMouseEvent + 0x416 (Qt6Widgets)
Quartus 0x7a358: QWidgetRepaintManager::updateStaticContentsSize + 0x2c78 (Qt6Widgets)
Quartus 0x783f0: QWidgetRepaintManager::updateStaticContentsSize + 0xd10 (Qt6Widgets)
Quartus 0x12f51: QApplicationPrivate::notify_helper + 0x151 (Qt6Widgets)
Quartus 0x12100: QApplication::notify + 0x16f0 (Qt6Widgets)
Quartus 0x97e14: QGuiApplicationPrivate::processMouseEvent + 0x7d4 (Qt6Gui)
Quartus 0xf0fe9: QWindowSystemInterface::sendWindowSystemEvents + 0xe9 (Qt6Gui)
Quartus 0x22941f: QEventDispatcherWin32::processEvents + 0x8f (Qt6Core)
Quartus 0x36fc28: QWindowsGuiEventDispatcher::processEvents + 0x18 (Qt6Gui)
Quartus 0xa8ad3: QEventLoop::exec + 0x1c3 (Qt6Core)
Quartus 0xa07bc: QCoreApplication::exec + 0x15c (Qt6Core)
Quartus 0x2bf7: qgq_py_wrap_main + 0x87 (quartus)
Quartus 0x29568: msg_initialize_out_of_memory_handler + 0x368 (ccl_msg)
Quartus 0x2a772: msg_set_stack_size + 0x92 (ccl_msg)
Quartus 0x2b033: mem_tbb_tracking_flush_peak + 0x773 (ccl_mem)
Quartus 0x2743f: msg_exe_main + 0x17f (ccl_msg)
Quartus 0x42ff: qtEntryPoint + 0x2f (quartus)
Quartus 0x3931: __scrt_common_main_seh + 0x105 (quartus)
Quartus 0x2e956: BaseThreadInitThunk + 0x16 (KERNEL32)
Quartus 0x427b: RtlUserThreadStart + 0x2b (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 11
OS version: 10.0.26200
Quartus Prime Information
Address bits: 64
Version: 26.1.0
Build: 110
Edition: Pro Edition
  • Hi BCuze
    Could you please share the design .QAR file so we can reproduce the internal error?
    Additionally, could you provide the steps to reproduce the issue?
    Richard Tan
  • BCuze's avatar
    BCuze
    Hi Richard,
    Unfortunately, I made many changes in the design and the tech map viewer doesn't display the same thing any more and I don't have the crash now.
    in Timequest :
    • setup summary
    • report timing
    • locate 1st path in tech map viewer
    • select page 2/2 -> crash
    It was reproducible (until I modified the design)
    I have nothing more to offer than the crash report.
    BR
    Bert
    • RichardT_altera's avatar
      RichardT_altera
      I’m glad to hear the issue has been resolved.
      Unfortunately, for cases involving Fatal or Internal errors, a design test case is required to reproduce the issue. Without being able to replicate it on our side, it is difficult to identify a workaround or solution.
      If you encounter an internal error in the future, please archive the project first before proceeding to made changes in the design.
      Richard Tan
