12 years ago
pwm verilog code
please help me to fnd pwm Verilog code
thank yu
    Your code will generate a wave that looks like a PWM !
    To create a PWM you need a duty cycle (how often do you want to refresh your signal) : You need to know your board frequency and compute the duty of your PWM ...
    The link I gave you explain that ! Follow the steps and stop jumping into coding something you don't understand
    I recommend you read the page carefully
    I hope this idea is correct.
    my fpga clock is 50mhz.that is period 20ns.
    I designed a pwm with 1000ns period.
    switch variable given as 2 to get 80 percent duty cycle.
    please check.
    Thankyou
    1000 ns =>
    P = 0.000001*50000000 = 50
    SC (Steps Count) = 2^3 = 8
    ==> sd = P / SC = 50/8 =6.25
    but you are using sd = 20 !
    Please read carefully the page (link I posted) and follow the steps ! It's not that hard !
    what is mean by refreshing signal?? I didn't get. can't i take p=1000ns?
    by refreshing signal we mean the time we need to have a new value (period)
    Yes you can take whatever period you want ! For 1000 ns P = 50 (because you multiply the 20 ns by 50 to get 1000 ns)
