9 years agoPush data pairs into stack
Hello everyone,
I'm doing image processing on FPGA, i'am programming connected component labeling exactly. So the problem is, that i have reached to program a stack for a certain purpose but i need to have an entry pair data (L min,L max) not just an input vector. I though about records but i don't think it is the right solution. I would be very grateful if you could help me clarify this matter.8 Replies
This is a very vague question - are you sure you meant to post this in the VHDL section?
What is exactly the problem? do you have some code showing the problem and better explain what you're trying to do? - Altera_Forum
I will make it so simple. I just want to to know how to write this in vhdl :
stack(ptr)<= (data_in1,data_in2) instead of stack(ptr)<=data_in. I can post the hole code and explain you the code and the project but i 'am afraid that i will complicate the idea because all i need is just what i wrote above. - Altera_Forum
just make the stack twice as wide and concatenate data_in1 and data_in2:
stack(ptr) <= data_in1 & data_in2; - Altera_Forum
This is my code for stack :
So for this line : stack_mem(stack_ptr) <= Data_In; my Data_In is actually a data pair and i need it to be like this stack_mem(stack_ptr) <= (Data_In1,Data_In1). I don't know how is it possible with vhdl . Any idea please ?library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity stack is generic( WIDTH : positive := 8 ; DEPTH : positive := 4); port( Clk : in std_logic; . Data_In : in std_logic_vector(WIDTH-1 downto 0); Data_Out : out std_logic_vector(WIDTH-1 downto 0); PUSH_barPOP,in_fv,in_dv : in std_logic; stack_Full : out std_logic; stack_Empty : out std_logic ); end stack; architecture Behavioral of stack is type mem_type is array (DEPTH-1 downto 0) of std_logic_vector(WIDTH-1 downto 0); signal stack_mem : mem_type := (others => (others => '0')); signal stack_ptr : integer := DEPTH-1; signal full,empty : std_logic := '0'; begin stack_Full <= full; stack_Empty <= empty; PUSH : process(Clk) begin if(rising_edge(Clk)) then if in_fv='1' then if in_dv='1' then if ( PUSH_barPOP = '1' and full = '0') then stack_mem(stack_ptr) <= Data_In; if(stack_ptr /= 0) then stack_ptr <= stack_ptr - 1; end if; --setting full and empty flags if(stack_ptr = 0) then full <= '1'; empty <= '0'; elsif(stack_ptr = DEPTH-1) then full <= '0'; empty <= '1'; else full <= '0'; empty <= '0'; end if; end if; else if (PUSH_barPOP = '0' and empty = '0') then Data_Out <= stack_mem(stack_ptr); if(stack_ptr /= DEPTH-1) then stack_ptr <= stack_ptr + 1; end if; if(stack_ptr = 0) then full <= '1'; empty <= '0'; elsif(stack_ptr = DEPTH-1) then full <= '0'; empty <= '1'; else full <= '0'; empty <= '0'; end if; end if; end if; end if; end if; end process; end Behavioral; - Altera_Forum
Unfortunately i need to be a pair not concatenated :(
TO_BE_DONE
What you are doing here is no different from concatenating the two inputs. You're storing 2 words at the same memory location.
As for your error - I dont know what it's refering to. Have you tried running this code in modelsim yourself, rather than via the quartus gui? - Altera_Forum
I will try your solution. Thank you so much for your help.
