9 years agoPush data pairs into stack
Hello everyone, I'm doing image processing on FPGA, i'am programming connected component labeling exactly. So the problem is, that i have reached to program a stack for a certain...
9 years agoThis is my code for stack :
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity stack is
generic( WIDTH : positive := 8 ; DEPTH : positive := 4);
port( Clk : in std_logic; .
Data_In : in std_logic_vector(WIDTH-1 downto 0);
Data_Out : out std_logic_vector(WIDTH-1 downto 0);
PUSH_barPOP,in_fv,in_dv : in std_logic;
stack_Full : out std_logic;
stack_Empty : out std_logic
end stack;
architecture Behavioral of stack is
type mem_type is array (DEPTH-1 downto 0) of std_logic_vector(WIDTH-1 downto 0);
signal stack_mem : mem_type := (others => (others => '0'));
signal stack_ptr : integer := DEPTH-1;
signal full,empty : std_logic := '0';
begin
stack_Full <= full;
stack_Empty <= empty;
PUSH : process(Clk)
begin
if(rising_edge(Clk)) then
if in_fv='1' then
if in_dv='1' then
if ( PUSH_barPOP = '1' and full = '0') then
stack_mem(stack_ptr) <= Data_In;
if(stack_ptr /= 0) then
stack_ptr <= stack_ptr - 1;
end if;
--setting full and empty flags
if(stack_ptr = 0) then
full <= '1';
empty <= '0';
elsif(stack_ptr = DEPTH-1) then
full <= '0';
empty <= '1';
else
full <= '0';
empty <= '0';
end if;
end if;
else
if (PUSH_barPOP = '0' and empty = '0') then
Data_Out <= stack_mem(stack_ptr);
if(stack_ptr /= DEPTH-1) then
stack_ptr <= stack_ptr + 1;
end if;
full <= '1';
empty <= '0';
full <= '0';
empty <= '1';
else
full <= '0';
empty <= '0';
end if;
end if;
end if;
end if;
end if;
end process;
end Behavioral; So for this line : stack_mem(stack_ptr) <= Data_In; my Data_In is actually a data pair and i need it to be like this stack_mem(stack_ptr) <= (Data_In1,Data_In1). I don't know how is it possible with vhdl . Any idea please ?
