10 years agoprogramming tool to download MAX10 firmware in 32-bit windows system
i am using 32-bits window system, and i would like to use this pc to do the firmware download to MAX10 FPGA. But the latest software which required to program the MAX10 required Quartus v14 and above (which needs 64-bits system). Do you have any idea on how to download the firmware to MAX10 fpga using 32-bit pc?
you look from here for xp usb blaster driver? seems like there is 32 bit version. But never tried with a 14.0 :D
https://www.altera.com/support/support-resources/download/drivers/dri-index.html - Altera_Forum
have you tried using an older version? If you have already the programming file it should work. - Altera_Forum
Do you still having problem with this?
Yes, i still have this problem. after installed the Quartus 14.1, i can install the USB Blaster driver for 32bit, but the "programmer" is still required 64bits PC to run. the Quartus 14.0 and above already required 64-bits system ...
