8 years ago
Programming DE1-SoC FPGA only from Quartus Prime Lite Edition Ubuntu 16.04
Hello, I am trying to simply program my CycloneV FPGA on the DE1-SoC board from Quartus Prime Lite in Ubuntu 16.04. I cannot seem to get it to work. The user guide says to do an auto-detect from the hardware programmer but the option is greyed out.
https://alteraforum.com/forum/attachment.php?attachmentid=15301&stc=1
I have also changed the USB configs in /etc/udev/rules.d/90-usbblaster.rules
# USB-Blaster
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666"
# USB-Blaster II
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6010", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6810", MODE="0666"
I still can not seem to find a way to get this thing programmed.
    jfrye@jfrye-Inspiron-5547:~$ sudo /home/jfrye/Quartus/quartus/bin/jtagconfig
    [sudo] password for jfrye:
    No JTAG hardware available
    Still nothing
    Did some more investigating and saw this
    jfrye@jfrye-Inspiron-5547:~$ lsusb
    Bus 001 Device 005: ID 0bda:5754 Realtek Semiconductor Corp.
    Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
    Bus 001 Device 003: ID 8087:07dc Intel Corp.
    Bus 001 Device 009: id 09fb:6810 Altera
    Bus 001 Device 002: ID 8087:8000 Intel Corp.
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    jfrye@jfrye-Inspiron-5547:~$ dmesg | tail
    [19384.983330] wlp2s0: authenticate with a0:ab:1b:75:f8:46
    [19384.985620] wlp2s0: send auth to a0:ab:1b:75:f8:46 (try 1/3)
    [19384.987823] wlp2s0: authenticated
    [19384.988216] wlp2s0: associate with a0:ab:1b:75:f8:46 (try 1/3)
    [19384.992448] wlp2s0: RX AssocResp from a0:ab:1b:75:f8:46 (capab=0x431 status=0 aid=2)
    [19385.003832] wlp2s0: associated
    [19385.003881] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
    [19411.895662] usb 1-1.3: new high-speed USB device number 9 using ehci-pci
    [19412.004477] usb 1-1.3: New USB device found, idvendor=09fb, idproduct=6810
    [19412.004481] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    That looks promising but I am not sure what exactly I have to do to make Quartus recognize the device is present to program it
    Then it's not a permission problem. I'm using Gentoo, but my USB blasters are identified by their name, e.g.
     usb 1-2: new high-speed USB device number 5 using ehci-pci
     usb 1-2: New USB device found, idVendor=09fb, idProduct=6010
     usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
     usb 1-2: Product: CV SoCKit
     usb 1-2: Manufacturer: Altera
    Unless there was a stale jtagd process left over when you were running as user jfrye.
    To rule out this you could try
    sudo killall -9 jtagd
    If that does not detect anything it might be related to the FTDI driver. Perhaps somebody with a Ubuntu 16.04 system have some input...
    I have the answer. I will provide my files
    /etc/udev/rules.d/51-usbblaster.rules
    SUBSYSTEM=="usb",
    ENV{DEVTYPE}=="usb_device",
    ATTR{idVendor}=="09fb",
    ATTR{idProduct}=="6810",
    MODE="0666",
    NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}",
    RUN+="/bin/chmod 0666 %c"
    # USB-Blaster
    # BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666"
    # BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666"
    # BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666"
    # USB-Blaster II
    # BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6010", MODE="0666"
    # BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6810", MODE="0666"
    /etc/udev/rules.d/altera-usb-blaster.rules
    ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="666"
    I also copied pgm_parts.txt into the bin directory, which also has jtagd. I then ran jtagd. After that everything worked
    Glad you got it working. I would assume killing jtagd and running jtagconfig as root would have detected the USB blaster since all the udev rules are doing is changing the permissions to 666.
