15 years ago
Problems with bidirectional signals in VHDL Testbench for ModelSim
Hi all,
I was just wondering if there is a simple way of implimenting bidirectional signals in a VHDL testbench I'm using ModelSim - Altera Starter Edition 6.5e and am very new to Quartus II, VHDL and FPGAs but feel I am making some progress slowly.
I have some bidirectional signals in my design, and in my testbench want to be able to put some inputs/stimuli into these, but also be able to see the outputs in the generated "wave" signal plot, as at the moment the values seem fine when acting as inputs but just give an X when they should be outputs as they are being assigned by both the test bench and my design but in different directions.
Any help is much appreciated even if its just a link to a clear explanation or example... I'm trying to look into it now, but so far haven't found anything that clear or a nice example...
Cheers
    this is the overview of my program.....the problem is in port maping .if i maped port in clockwise direction then what can i do for counter clock wise portmaping.?
    THis would be a single entity, you wouldnt need any port mapping.
    Post the code and the errors and we can help.
    if (sel= 0) then
    ch0: noc
    PORT MAP(
    clk => clk,
    reset => reset,
    data_in => mDch_buffer0,
    parity_in =>mPch_buffer0,
    bflag_in => mch0_busy,
    --bflag_out : out std_logic;
    parity_out => mP_buffer1, ---line 950
    data_out =>mD_buffer1 );
    elsif (sel= 1) then---- line 952
    PORT MAP(
    clk => clk,
    reset => reset,
    data_in => mDch_buffer1,
    parity_in =>mPch_buffer1,
    parity_out => mP_buffer0,
    data_out =>mD_buffer0 );
    end if;
    ** Error: C:/Modeltech_5.7g/examples/nov5.vhd(950): near ";": expecting: ')'
    ** Error: C:/Modeltech_5.7g/examples/nov5.vhd(952): near "then": expecting: <= :=
    --- Quote Start ---
    if (sel= 0) then
    ch0: noc
    PORT MAP(
    clk => clk,
    reset => reset,
    PORT MAP(
    clk => clk,
    reset => reset,
    end if;
    --- Quote End ---
    what you need in this case is one port map but then connect signals in the logic. e.g
    port map
    data_in => data_in,
    data_out => data_out,
    then in your logic:
    if sel = '0' then
        data_in <= mDch_buffer0;
        mD_buffer1 <= data_out;
    else
        data_in <= mDch_buffer1;
        mD_buffer0 <= data_out;
    end if;
    i started t resolve my solution from base .
    this is the simple counter program of my project .
    library ieee ;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    entity counter is
    port( clk: in std_logic;
    reset: in std_logic;
    load: in std_logic;
    data: in std_logic_vector(3 downto 0);
    busy : out std_logic;
    dcount: out std_logic_vector(3 downto 0);
    end counter;
    architecture behav of counter is
    signal pre_count: std_logic_vector(3 downto 0);
    signal dec: std_logic_vector(3 downto 0);
    begin
    process(clk,reset)
    begin
    if reset = '1' then
    pre_count <= "0000";
    busy<='0';
    elsif (clk='1' and clk'event) then
    if load = '1' then
    dec<=data;
    busy<='1';
    elsif dec >0 then
    dec<=dec-'1';
    pre_count <= pre_count + "1";
    elsif dec= 0 then
    busy<='0';
    end if;
    end if;
    end process;
    dcount <=dec;
    count <= pre_count;
    end behav;
    library ieee ;
    use ieee.std_logic_textio.all;
    use std.textio.all;
    entity counter_tb is
    end;
    architecture counter_tb of counter_tb is
    COMPONENT counter
    PORT ( clk: in std_logic;
    load: in std_logic;
    count: out std_logic_vector(3 downto 0) );
    END COMPONENT ;
    SIGNAL clk : std_logic := '0';
    SIGNAL reset : std_logic := '0';
    SIGNAL load,cheko : std_logic := '0';
    Signal data: std_logic_vector(3 downto 0):="1010" ;
    SIGNAL busy : std_logic;
    SIGNAL count : std_logic_vector(3 downto 0);
    signal dcount: std_logic_vector(3 downto 0);
    begin
    dut : counter
    PORT MAP (
    count => count,
    clk => clk,
    load=> load,
    busy=> busy,
    data=> data,
    dcount =>dcount,
    reset => reset );
    chekoo : PROCESS
    begin
    if ( busy ='1') then
    cheko <='1';
    elsif ( busy ='0') then
    cheko <='0';
    else
    cheko <='0';
    end if;
    end process chekoo;
    clock : PROCESS
    begin
    wait for 1 ns; clk <= not clk;
    end PROCESS clock;
    stimulus : PROCESS
    begin
    load <= '0';
    wait for 5 ns; reset <= '1';
    wait for 4 ns; reset <= '0';
    wait for 4 ns; load <= '1';
    wait for 2 ns; load <= '0';
    wait;
    end PROCESS stimulus;
    end counter_tb;
    WARNING[2]: C:/Modeltech_5.7g/examples/nov5.vhd(93): Possible infinite loop: process has no wait statement.
    All processes must have either a wait statement or a sensitivity list, otherwise they will loop forever in 0 time. You chekkoo process probably needs a sensitivity list with bust in it.
