12 years ago --- Quote Start --- if (sel= 0) then ch0: noc PORT MAP( clk => clk, reset => reset, data_in => mDch_buffer0, parity_in =>mPch_buffer0, bflag_in => mch0_busy, --bflag_out : out std_logic; parity_out => mP_buffer1, ---line 950 data_out =>mD_buffer1 ); elsif (sel= 1) then---- line 952 PORT MAP( clk => clk, reset => reset, data_in => mDch_buffer1, parity_in =>mPch_buffer1, bflag_in => mch0_busy, --bflag_out : out std_logic; parity_out => mP_buffer0, data_out =>mD_buffer0 ); end if; ** Error: C:/Modeltech_5.7g/examples/nov5.vhd(950): near ";": expecting: ')' ** Error: C:/Modeltech_5.7g/examples/nov5.vhd(952): near "then": expecting: <= := --- Quote End --- what you need in this case is one port map but then connect signals in the logic. e.g
port map
data_in => data_in,
data_out => data_out,
then in your logic:
if sel = '0' then
data_in <= mDch_buffer0;
mD_buffer1 <= data_out;
else
data_in <= mDch_buffer1;
mD_buffer0 <= data_out;
end if;
