Problemas con Quartus
Tengo todo descargado para poder utilizar Quartus, pero a la hora de querer crear un archivo me sale esta leyenda "Can't open project -- you don't have permission to write to all the files or create new files in the project database directory". En las preguntas encontré un comentario parecido que mencionaba algo de los bits y da la solución con un comando (attribut -R/ S/ D/ *) también ya lo intenté y sigue igual. Espero puedan ayudarme a resolver esto ya que lo ocupo para la escuela.
- sstrell
What location did you specify for the project directory? Obviously if it's a location that you don't have access to or can't write to, then you would see this issue. Can you put the project somewhere else?
- RichardT_altera
Translation:
I have everything downloaded to be able to use Quartus, but when I try to create a file I get this message: "Can't open project -- you don't have permission to write to all the files or create new files in the project database directory". In the questions I found a similar comment that mentioned something about bits and gives the solution with a command (attribut -R/ S/ D/ *) I also tried it and it's still the same. I hope you can help me solve this since I need it for school.
As mentioned by sstrell, check that you have permission to edit the file in the project directory.
When you create a new project, Quartus by default will use the Quartus installation directory, which you might not have permission to edit/write.
Change the working directory for your project and see if the issue still persists.
Richard Tan
- RichardT_altera
Any update on this?
Do you able to resolve the issue?
Richard Tan
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
