17 years ago
Problem with VHDL code
Hi I'm really really new to VHDL codes and I'm having this problem with a very simple program of mine. The code is as shown below:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity cc is
port (
enter : in std_logic;
reset : in std_logic;
input : in signed (7 downto 0);
output : out signed (7 downto 0)
end cc;
architecture cc_arch of cc is
signal a : signed (7 downto 0);
signal b : signed (7 downto 0);
signal total: signed (7 downto 0);
signal c : std_logic;
signal d : std_logic;
begin
process (enter,reset)
begin
if (reset = '0' and enter = '1') then
total <= "00000000";
end if;
if (enter = '1' and reset = '1') then
a <= input;
b <= total;
elsif (enter = '0' and reset = '1') then
total <= a + b;
end if;
end process;
output <= total;
end cc_arch;
The program is supposed to act as a simple calculator which calculates 2's complement. The buttons RESET and ENTER are active low buttons. "Input" is a 8 bit DIP switch.
I intended the program to function as shown below:
When RESET button is pressed, total is set to 0.
Then "Input" is put into "a" and total is put into "b" when no button is pressed.
When ENTER button is pressed the total is set to (a + b). When it is released, "Input" is put into "a" again and total is put into "b".
When the ENTER button is pressed again and again, total is supposed to be incremented with whatever is at "Input".
However when I simulated it, by setting Input to "00000002" as a simple example i get:
http://img300.imageshack.us/img300/6630/waveformfd6.jpg (http://imageshack.us)
http://img300.imageshack.us/img300/waveformfd6.jpg/1/w640.png (http://g.imageshack.us/img300/waveformfd6.jpg/1/)
Please help I'm not exactly sure what's happening.
http://img442.imageshack.us/img442/59536805yw2.jpg/1/w320.png (http://g.imageshack.us/img442/59536805yw2.jpg/1/)
    --- Quote Start ---
    begin
    end if;
    a <= input;
    b <= total;
    total <= a + b;
    end if;
    end process;
    --- Quote End ---
    You are trying to imply storage i.e. a FlipFlop for and b.
    The process above is not correct coding for a synchronous process and hence will not synthesize to any flipflops.
    I suggest you read up about synchronous design for VHDL.
    BUT....
    Something like
    process (clk)
    begin
    if (clk'event and clk= '1') then
    elsif (enter = '1' and reset = '1') then
    a <= input;
    b <= total;
    total <= a + b;
    end if;
    end if;
    end process;
    might be a start.
    The line if (clk'event and clk= '1') then effectively means wait for a rising edge on the clk signal.
    You will need to provide a clock generator to your design.
    Hope this gives you some clues!
    Let me know how you get on
    * I advice you to use reset_n to indicate an active low signal.
    * to use std_(u)logic and std_(u)logic_vector only for ports
    * Use indent for better readability (if not), comments (not too much)...
    * You can find VHDL coding style in altera Web site or otherwhere.
    * In process sensibility list (if it is not a process clk), you must enter all input process signals if you don't want to infer latches.
    process (reset_n,order_n, input, a, b)
    @Vernmid : there is NO clock signal. So no process(clk)
    2) you should initialize all signals at reset_n and make reset_n the most priority signal
    [darkred]begin
    if reset_n = '0' then -- only reset_n
    --all initializations here
    a <= 0;
    b <= 0;
    elsif enter_n = '1' then -- (obviously reset_n = '1')
    a <= input;
    b <= total;
    else -- imply (enter = '0' and reset = '1')
    total <= a + b;
    end if;
    end process;
    * The behaviour above is asynchronous : you have glitches, combin. loops (very instable), sometimes latches.
    Very hard to debug if contains loops.
    Asynchronous design is usually used to make decoders, MUX, RS, tristate bus ...
    As Vernmid said, you are recommanded to use
    process(reset_n, clk)
    begin
    elsif rising_edge(clk) then
    if enter_n = '0' then
    else
    end if;
    end if;
    end process;
    Quartus give templates.
    Keep in mind that you create logic design.
    May the force be with you :-)
    Hi.. Thanks for all your help.. I've tried adding:
    if (clk'event and clk ='1') then
    end if;
    And now the program works fine.. Thanks loads..
