yudi7863
1 year agoProblem with using ISSP in quartus: Instance not found
Hi there, I have compiled an Agilex project with ISSP instantiated using Quartus_Pro. However, at runtime, I don't have access to quartus_pro on my laptop. So instead, I downloaded a quartus_lite v...
sstrell
1 year agoYou should download the Programmer, not the Lite edition, which doesn't work with Agilex devices.
But I'm not sure that the Programmer standalone installation actually lets you access an ISSP instance since its main thing is programming the device and letting you access a Signal Tap instance. It's a small download, so you might as well try it.
