bit
6 years agoProblem with terasIC DE0-CV borad (Cylone V FPGA) and different versions of the Quartus Prime Lite
Hi!
I have a problem with a terasIC DE0-CV borad (Cylone V FPGA) and different versions of the Quartus Prime Lite Edition.
I created the hack computer from the Nand To Tetris project on this boar...
KhaiChein_Y_Intel
6 years agoHi Helmut,
Could you share the design for investigation?
KhaiY
bit
6 years agoHi KhaiY,
here are all design files and a short usage description:
- Unzip the archive "Hack Computer.zip"
- Start Quartus Prime Lite Edition (17.0)
- Create the project with the "New Project Wizard"
- Select as working directory the created folder “Hack Computer”
- Use as project and top-level entity name "computer"
- Select as project type "Empty project"
- Add All Files form the working directory
- Select as Device "5CEBA4F23C7"
- Finish the "New Project Wizard"
- Import the default DE0-CV assignments:
Assignments, Import Assigments: DE0CV_default_assignments.qsf
(from project directory) - Compile
- Program the board (you need a vga monitor and a qwertz-ps2-keyboard)
- Play pong
Helmut
