Problem with simulation quartus II web edition
Hi there, many old version are not supported by Win11. You may try Win10 which can support more version of Quartus.
However, many of my classmates use Windows 11 without any issues (on a PC with native Windows 11, not through a virtual machine). Besides the problem mentioned earlier, I noticed that when I click on 'EDA Netlist Writer', the following error appears:
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3776
Stack Trace:
0x43282: DYGR_ROUTE_TIMING_INFO::get_timing_node + 0xd6c2
0x131b0: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xaf0
0x12e3c: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0x77c
0x127ed: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0x12d
0x15b3a: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x5a
0x1afd1: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x191
0x2829: DYGR_PLACE_INFO_BODY::load_data + 0x29
0x289e: DYGR_PLACE_INFO::load_data + 0x3e
0x2a31: DYGR_DIE_INFO_BODY::load_data + 0x131
0x1951d: MPP_ROOT::start + 0x5bd
0x6bba: Legacy_fitter_Init + 0x5b4a
0x1e0f: Legacy_fitter_Init + 0xd9f
0x2e68: Legacy_fitter_Init + 0x1df8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xbd5f: qexe_ipc_progress_bar_name + 0xf3f
0x11498: qexe_get_command_line + 0x1068
0x147a5: qexe_run_tcl_option + 0x585
0x1dacd: qcu_run_tcl_option + 0xb8d
0x14dbd: qexe_process_cmdline_arguments + 0x54d
0x14f21: qexe_standard_main + 0xa1
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
0xf09fb: uaw_wcsrchr + 0xeaf3b
0x87baf: uaw_wcsrchr + 0x820ef
0x1bc4c7: ZwWaitLowEventPair + 0x1add47
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed: 1
At this point, I would be inclined to say that it is a problem caused by running the program on a virtual machine, even though one of my classmates is doing exactly the same thing and has no issues.
