16 years agoProblem with programming in AS mode with Quartus rogrammer
Hi there, the problem is that the output .pof file from compilation is not correct, the message is:
Error: Can't recognize silicon ID for device 1 I checked the default program of DE1 board and found out that the device for active serial programming is "EPCS4", while the compilation .pof file is "EPCS16". How can i fix that? Regards, Kevin PS: There is no problem with JTAG, the device in project properties is "EP2C20F484C7"
