TRoa
6 years agoProblem with Gate level simulation
Hi, I made a simple design for just experimentation. In that design, I instantiated a multiplier from IP catalog(simple multiplier). Then I synthesized. Everything was ok. Then I wrote a testbench a...
RichardT_altera
6 years agoHave you followed the Gate-Level Simulation (NativeLink Flow) as per the user guide?
TRoa
6 years agoThe problem was timing. The model or the IP was not starting till 4995 ps . So What I did, I regenerated that IP with same specs, but with little less files(this time only with .v files). And problem was solved.
Now, no starting delays and IP is also working with peco seconds accuracy.
Thanks for your replay.
