MDiDo
6 years agoProblem with Deinterlacer
Hello, I have a problem with the Deinterlacer IP Core. I created a video system with the following input chain: CVI->CLIPPER->COLOR PLANE SEQUENCER->CHROMA RESAMPLE->DEINTERLACER->MEMORY CONTROLLER-...
CheepinC_altera
6 years agoHi,
Thank for your update. For your information, I am using Modelsim - Intel FPGA Edition 10.5b at which this design is created and tested with, based on previous information that I got from wiki. You might want to try with Modelsim to see if it works as a workaround.
Thank you very much.
Chee Pin
MDiDo
6 years agoIf I use Modelsim it correctly works. Anyway I need use QuestaSim in order to create an UVM testbench. I'll try with an other QuestaSim version.
