MDiDo
6 years agoProblem with Deinterlacer
Hello, I have a problem with the Deinterlacer IP Core. I created a video system with the following input chain: CVI->CLIPPER->COLOR PLANE SEQUENCER->CHROMA RESAMPLE->DEINTERLACER->MEMORY CONTROLLER-...
MDiDo
6 years agoI received your email. The email text is as follows:
A10 simple simulation example with TPG -> DIL -> CVO in Q17.0
ref:_00DU0YT3c._5000Pq1DlN:ref
But I don't see any simulation example. I haven't received the attached file. Could you send me the file again? Thank you.
CheepinC_altera
6 years agoHi,
Sorry for the inconvenience. I will attempt to re-send the file again after splitting the file into smaller size in case it was filtered out by server.
I will let you know again once it is done.
Chee Pin
