problem with Arria10 qdz file
hello,
I've been trying to install Quartus Prime Pro version 18.1 and i keep running into the following problem: whether i download the single file or multiple files, I run into the error while unzip the Arria10 qdz file. Anybody else sees this problem? How do i get around this?
See attached screen shot for error message.
- sstrell
You don't need to unzip/extract a .qdz file. If you have already downloaded the .qdz file and placed it in the same directory as the Quartus installer, the installer will ask if you want to install the device during the installation process. If you've already installed Quartus, use the Device Installer application (added to Start menu if you're on Windows) to point to your existing Quartus installation and the downloaded .qdz file.
#iwork4intel
- KennyT_altera
Actually, you need the qdz files. this is use in Quartus tools -> device installer.
can you try other device to see if this happened as well? Can you put out the link where you download the zip files?
- KennyT_altera
Any update?
- DNguy4
seems to be related to internet explorer.
- KennyT_altera
Oic. so it had been resolve using other browser?
- DNguy4
yes, you can close this case.
- KennyT_altera
Any update?
