DNguy4
6 years agoproblem with Arria10 qdz file
hello, I've been trying to install Quartus Prime Pro version 18.1 and i keep running into the following problem: whether i download the single file or multiple files, I run into the error while unzi...
sstrell
6 years agoYou don't need to unzip/extract a .qdz file. If you have already downloaded the .qdz file and placed it in the same directory as the Quartus installer, the installer will ask if you want to install the device during the installation process. If you've already installed Quartus, use the Device Installer application (added to Start menu if you're on Windows) to point to your existing Quartus installation and the downloaded .qdz file.
#iwork4intel
