DNguy4
6 years agoproblem with Arria10 qdz file
hello, I've been trying to install Quartus Prime Pro version 18.1 and i keep running into the following problem: whether i download the single file or multiple files, I run into the error while unzi...
KennyT_altera
6 years agoActually, you need the qdz files. this is use in Quartus tools -> device installer.
can you try other device to see if this happened as well? Can you put out the link where you download the zip files?
