8 years agoProblem with aocl install
I have a problem with the installation command "aocl install<path_custom_platform>", because of the bash returns the following problem: "is not an object at /home/intel_tools/intelFPGA_pro/17.1/hld/share/lib/perl/acl/Command.pm line 1290, <F> line 34." I am using a virtual machine with centOS 7.4 on Windows server 2012 R2. I attached the screenshot of the problem. Can anyone help me? Thanks for your help.17 Replies
Click on "this workaround" posted by nicolacdnll
--- Quote Start --- And the workaround is?? --- Quote End --- You probably didn't see the link that reads: --- Quote Start --- Workaround To avoid this error, apply following changes to the <OpenCL SDK Installation Path>/share/lib/perl/acl/Command.pm: lines 110 &111 Line 110: Replace isWindowsOS() ->acl::Env::is_windows() Line 111: Replace mysystem_full({}, @cmd); -> system(@cmd); --- Quote End --- - Altera_Forum
Thanks guys! I totally overlooked it, very sneaky...
I just wanted to add that it seems this was fixed in SDK v17.1 Update 1.
The update release notes (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/rn/rn_qts_dev_support_update.pdf) at page 18 reads:Fixed an issue where the aocl install command failed with message similar to the following example: is not an object at <path_to_command.pm>/Command.pm line 1241, <F> line 68. - Altera_Forum
--- Quote Start --- I just wanted to add that it seems this was fixed in SDK v17.1 Update 1. The update release notes (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/rn/rn_qts_dev_support_update.pdf) at page 18 reads:
--- Quote End --- I don't think it has been released yet, at least, I can't find it...Fixed an issue where the aocl install command failed with message similar to the following example: is not an object at <path_to_command.pm>/Command.pm line 1241, <F> line 68. - Altera_Forum
--- Quote Start --- I don't think it has been released yet, at least, I can't find it... --- Quote End --- It was released a while ago and they already released a newer version, namely Update 2, go to http://dl.altera.com/opencl/17.1/?edition=pro&download_manager=direct and select Update tab. But, make sure your board vendor has a BSP for this version of the SDK. - Saikiranbelana
Iam trying to dockerize intel_rte_stack. After dockerization, the docker container was able to detect fpgas attached via PCIe with
fpgainfo fmeOutput:
root@4a694037e7ce:~# fpgainfo fme Board Management Controller, microcontroller FW version 26895 Last Power Down Cause: POK_CORE Last Reset Cause: None //****** FME ******// Object Id : 0xEF00000 PCIe s:b:d:f : 0000:86:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x124000200000367 Bitstream Version : 1.2.4 Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c Boot Page : userBut when I try to run aocl install, the following errors occurs and it says, Intel PAC device
root@4a694037e7ce:~/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl# aocl install Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege Install the FCD file to /opt/Intel/OpenCL/Boards aocl install: Adding the board package /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp to the list of installed packages Installing the board package driver to the system. aocl install: Running install from /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec WARNING: Intel PAC device not foundCan someone please help me out in resolving these issues or if you have some proper documentation, please share
