11 years ago
Problem with accessing the DE1 board SRAM
I am having trouble reading the SRAM on the DE1 board :(. Below are the code used to access the SRAM. My objective is to write data to an address once and read that particular address more than once. The tester_clock runs at the speed of 100MHz. The picture uploaded is the block diagram for the system.
The pins were analysed by SignalTap. The data x"0505" seems to be transmitting to the SRAM. However, I received no responds from the SRAM.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_signed.all;
entity sram_test is
port(
SRAM_ADDR : out std_logic_vector (17 downto 0);
SRAM_DQ : out std_logic_vector (15 downto 0);
SRAM_WE_N : out std_logic;
SRAM_OE_N : out std_logic;
SRAM_UB_N : out std_logic := '0';
SRAM_LB_N : out std_logic := '0';
SRAM_CE_N : out std_logic := '0';
tester_clock: in std_logic
end entity;
architecture rtl of sram_test is
signal in_SRAM_WE_N : std_logic := '0';
begin
process (tester_clock)-------------
begin
if (rising_edge(tester_clock)) then
if (in_SRAM_WE_N = '0') then -- Write mode
SRAM_ADDR <= (others => '0'); -- Address location 0 selected
SRAM_WE_N <= '0';
SRAM_OE_N <= '1';
SRAM_DQ <= x"0505"; -- Write data to selected address
in_SRAM_WE_N <= '1'; -- Switch to read mode
elsif (in_SRAM_WE_N = '1') then -- Read mode
SRAM_WE_N <= '1'; -- Read mode selected
SRAM_OE_N <= '0'; -- Output enabled
end if;
end if;
end process;
end rtl;
http://www.alteraforum.com/forum/attachment.php?attachmentid=10709&stc=1
