11 years agoProblem with accessing the DE1 board SRAM
I am having trouble reading the SRAM on the DE1 board :(. Below are the code used to access the SRAM. My objective is to write data to an address once and read that particular address more than once....
11 years agoI am not familiar with the SRAM, but I found this example: http://pentevo.googlecode.com/svn/fpga/tests/test_dram/sram_control.v
There the SRAM is controlled with a three cycle write. Might it be that you require the same?
