16 years ago --- Quote Start --- always@(posedge TCK or posedge TCS) begin ... end --- Quote End --- is actually ambiguous, because the meaning of Verilog posedge depends on the following code. But it makes sense only in this form:
begin
if (TCS)
else
end The respective VHDL equivalent is process(TCS,TCK)
begin
if TCS = '1' then
elsif rising_edge(TCK)
end if;
end; You'll find various Altera Forum threads discussing the same. Also Quartus HDL templates can help you to understand the basic concepts of both languages. I guess, you understand, that the asynchronous processing of TCS in the present code creates a different behaviour than your previous posting.
