16 years agoIndeed we find the test bench of the system at the end of the file. So I add my component with "component" and then "port map", but I have the following warning in ModelSim, and indeed, the component does not appear in the instances :
"Warning: (vsim-3473) Component instance "cut : testcomponent" is not bound." I think it is because it does not know where find the vhdl file corresponding to my component, but I don't know how to do it.
entity test_bench is
end entity test_bench;
architecture europa of test_bench is
component processor is
port (
-- 1) global signals:
signal clk : IN STD_LOGIC;
signal reset_n : IN STD_LOGIC;
-- the_led_pio
signal out_port_from_the_led_pio : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
-- the_test_component_conduit
signal coe_avs_address_from_the_test_component_conduit : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
signal coe_avs_chipselect_from_the_test_component_conduit : OUT STD_LOGIC;
signal coe_avs_read_from_the_test_component_conduit : OUT STD_LOGIC;
signal coe_avs_readdata_to_the_test_component_conduit : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
signal coe_avs_write_from_the_test_component_conduit : OUT STD_LOGIC;
signal coe_avs_writedata_from_the_test_component_conduit : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
signal coe_csi_clk_from_the_test_component_conduit : OUT STD_LOGIC;
signal coe_csi_reset_from_the_test_component_conduit : OUT STD_LOGIC
end component processor;
signal clk : STD_LOGIC;
signal coe_avs_address_from_the_test_component_conduit : STD_LOGIC_VECTOR (7 DOWNTO 0);
signal coe_avs_chipselect_from_the_test_component_conduit : STD_LOGIC;
signal coe_avs_read_from_the_test_component_conduit : STD_LOGIC;
signal coe_avs_readdata_to_the_test_component_conduit : STD_LOGIC_VECTOR (31 DOWNTO 0);
signal coe_avs_write_from_the_test_component_conduit : STD_LOGIC;
signal coe_avs_writedata_from_the_test_component_conduit : STD_LOGIC_VECTOR (31 DOWNTO 0);
signal coe_csi_clk_from_the_test_component_conduit : STD_LOGIC;
signal coe_csi_reset_from_the_test_component_conduit : STD_LOGIC;
signal cpu_data_master_irq : STD_LOGIC_VECTOR (31 DOWNTO 0);
signal out_port_from_the_led_pio : STD_LOGIC_VECTOR (7 DOWNTO 0);
signal reset_n : STD_LOGIC;
-- <ALTERA_NOTE> CODE INSERTED BETWEEN HERE
--add your component and signal declaration here
component TestComponent is
port(csi_clk : IN STD_LOGIC;
csi_reset : IN STD_LOGIC;
avs_chipselect : IN STD_LOGIC;
avs_write : IN STD_LOGIC;
avs_read : IN STD_LOGIC;
avs_address : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
avs_writedata : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
avs_readdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0)
end component;
-- AND HERE WILL BE PRESERVED </ALTERA_NOTE>
begin
--Set us up the Dut
DUT : processor
port map(
coe_avs_address_from_the_test_component_conduit => coe_avs_address_from_the_test_component_conduit,
coe_avs_chipselect_from_the_test_component_conduit => coe_avs_chipselect_from_the_test_component_conduit,
coe_avs_read_from_the_test_component_conduit => coe_avs_read_from_the_test_component_conduit,
coe_avs_write_from_the_test_component_conduit => coe_avs_write_from_the_test_component_conduit,
coe_avs_writedata_from_the_test_component_conduit => coe_avs_writedata_from_the_test_component_conduit,
coe_csi_clk_from_the_test_component_conduit => coe_csi_clk_from_the_test_component_conduit,
coe_csi_reset_from_the_test_component_conduit => coe_csi_reset_from_the_test_component_conduit,
out_port_from_the_led_pio => out_port_from_the_led_pio,
clk => clk,
coe_avs_readdata_to_the_test_component_conduit => coe_avs_readdata_to_the_test_component_conduit,
reset_n => reset_n
process
begin
clk <= '0';
loop
wait for 10 ns;
clk <= not clk;
end loop;
end process;
PROCESS
BEGIN
reset_n <= '0';
wait for 200 ns;
reset_n <= '1';
WAIT;
END PROCESS;
--add additional architecture here
CUT : TestComponent
port map(csi_clk => coe_csi_clk_from_the_test_component_conduit,
csi_reset => coe_csi_reset_from_the_test_component_conduit,
avs_chipselect => coe_avs_chipselect_from_the_test_component_conduit,
avs_write => coe_avs_write_from_the_test_component_conduit,
avs_read => coe_avs_read_from_the_test_component_conduit,
avs_address => coe_avs_address_from_the_test_component_conduit,
avs_writedata => coe_avs_writedata_from_the_test_component_conduit,
avs_readdata => coe_avs_readdata_to_the_test_component_conduit);
end europa;
--synthesis translate_on
