ARach7's avatar
ARach7
7 years ago
Problem at source files generated by Quartus from user’s “platform design” session (qsys).
  1. Port connection width mismatches at 2 altera pcie files, “altpciexpav_stif_rx.v” and “altpciexpav_stif_tx.v”.
  2. Error-[ANALERR_SIZEMISMATCH1] Size mismatch
  3. Parameter override type mismatches at various files. Qsys creates wrappers with mismatching types between Verilog and VHDL (attempt to override integer parameter with generic string).
  4. Error-[OVA1ACTUALTYPEMISMATCH_COMPONENT_ENTITY] Type mismatch
We have no access to customer files generated by QSYS, and there will not be such access.
All we can provide is an example that gives above errors as follows:
%vlogan -sverilog t.v
%vhdlan t.vhd
%vcs tb
Top Level Modules:
tb
t.vhd, 16
CHILD
Line 1.3:
Please generate .lis file by 'vhdlan -list ...' and see details.
--+ generic map (AR => AR)
Actual 'AR' is STRING, but formal 'AR' is STD_LOGIC_VECTOR when binding
component 'CHILD'(t.vhd:15) to entity 'CHILD'(t.v:1).Instance label is
'UUT'(t.vhd:21).
Mismatch found between the actual named 'DATA', whose type size is 7, and
the formal named 'DATA', whose type size is 8. Actual 'DATA' is defined in
COMPONENT named CHILD in file t.vhd at line 18. Formal 'DATA' is defined in
MODULE named CHILD in file t.v at line 1.
%cat t.v
module child #(parameter integer ar = 0 ) (input clk, output [7:0] data) ;
endmodule
module tb ();
Ent uut ();
endmodule
%cat t.vhd
use STD.textio.all;
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_textio.all;
entity Ent is
end Ent;
Architecture Arc of Ent is
signal TP : std_logic ;
signal MY_DATA : std_logic_vector (6 downto 0) ;
component CHILD
generic ( ar : string := "0" );
Port ( CLK : In std_logic;
DATA : OUT std_logic_vector (6 downto 0) );
end component;
begin
UUT : CHILD
Port Map ( CLK => TP, DATA=>MY_DATA );
end Arc;
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Can you give more information on
    1. Quartus tool version & edition used?
    2. Device PN?
    3. Full name of the IP used? Also, it's configuration.
    Anand
  • ARach7's avatar
    ARach7
    1.quartus_18.1.1.646
    2.PCIE
    I have no more info, this issue was observed at 3rd party who tried to use VCS with Quartus.
  • ARach7's avatar
    ARach7
    ​Thanks for the file pointers.
    My customer, who is using Quartus with VCS, got the errors I described in this post, on these files that are used in his Qsys design.
    He claims that it is qsys did these mistakes of overriding Verilog parameter "CB_PCIE_MODE" of module altpciexpav_stif_rx, whose type is the default type (integer) with value 0, with VHDL generic of type string, with value "0".
    Is it possible for Qsys to do such typo, or is it eventually a user error?
    AnandRaj_S_Intel
    No, Qsys can't change its configuration without user inputs(configuration) for an IP.
    Try by regenerating the Qsys system or creating a simple project with a PCIe IP alone.
    Anand
