GBraj
6 years agoPrime Pro 19.1 and 19.4 -- IP Catalog -- Invoking "Fixed Point Functions Intel FPGA IP", entering a name and clicking OK crashes.
I am targeting an Arria 10 device, I want to use the adder and the square root. After launching the IP and entering the name for saving, the application disappears. No warning or message. Tried on t...
GBraj
6 years agoHi Syafieq,
unfortunately no .rpt file related to the Fixed Point Functions IP has been generated in my project directory. I have the others .rpt files related to the other IP cores that I'm using.
If helps, I found this closed topic https://forums.intel.com/s/question/0D50P00004MvmSlSAJ/in-prime-pro-191-ip-catalog-invoking-fixed-point-functions-intel-fpga-ip-entering-a-name-and-clicking-ok-crashes?language=en_US with the same issue. It seems a bug related to the XML parser of Quartus Pro 19.1 and it was said that it will be fixed in 19.3.
However, I have the same behaviour in 19.4. Do you want that I install the 19.3 version and try the same steps?
Regards.
