RZhen11
6 years agopreserve attribute doesn't seem to work for me
Dear Support,
I'm having hard time working with SignalTap, can't find signals I'm interested easily.
attribute preserve: boolean;
attribute preserve of Signal1 : signal is true;
attribute pres...
sstrell
6 years agoIf a signal does not show up in the Signal Tap pre-synthesis or post-fitting filter, there's a reason why the signal cannot be tapped, such as an output signal to a pin (no route back into the device) or a signal on a carry chain route (no route out of the carry chain). What are the signal(s) you are trying to tap?
If you can provide code, maybe the forum can help you add code to bring the signal out in a way that it can be tapped.
#iwork4intel
