AEsqu
Contributor
3 years agoPreservation level: Final leads to Quartus crash on re-run
Preservation level: Final leads to Quartus crash on re-run. Quartus does not crash when I use the synthesize preserve level (or no preserve). Crash log + picture after the crash message (closed). ...
Nurina
3 years agoHi,
I think the root cause of it all is that you are using Quartus 22.4 on Red Hat 7 which isn't supported: https://cdrdv2.intel.com/v1/dl/getContent/758928?fileName=rn-qts-pro-dev-support-683706-758928.pdf
Please use a supported OS. If you are using an unsupported OS, we cannot help you as it is expected for Quartus not to work with an unsupported OS. Otherwise you can use an older version of Quartus that supports Red Hat 7, please check for latest Quartus OS support here: https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html
Nurina
