PowerPlay Power Analyzer error
Thanks for reply.
I got this output :
Info: Running Quartus Prime Assembler
Info: Version 17.0.0 Build 595 04/25/2017 SJ Standard Edition
Info: Processing started: Sun Dec 31 15:34:08 2023
Info: Command: quartus_asm --read_settings_files=off --write_settings_files=off C86S105 -c C86S105
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Warning (292011): Can't generate programming files because you are currently using the Quartus Prime software in Evaluation Mode.
Info: Quartus Prime Assembler was successful. 0 errors, 2 warnings
Info: Peak virtual memory: 4676 megabytes
Info: Processing ended: Sun Dec 31 15:34:11 2023
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:00
Info: *******************************************************************
Info: Running Quartus Prime PowerPlay Power Analyzer
Info: Processing started: Sun Dec 31 15:34:12 2023
Info: Command: quartus_pow --read_settings_files=off --write_settings_files=off C86S105 -c C86S105
Error (215039): PowerPlay Power Analyzer (quartus_pow) cannot be run. It requires a successful run of the Assembler. The Assembler (quartus_asm) failed or was not run.
Error: Quartus Prime PowerPlay Power Analyzer was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 4670 megabytes
Error: Processing ended: Sun Dec 31 15:34:12 2023
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:00
