possiblity of unstable reset lead to misoperation
There's a problem that makes us confus.
The input reset signal is like this
The unstable part would stay about 40 ms long.
Here's our source code for trigger
Here's the waveform in SignalTap
When sig_A & sig_B is all 0
edge_sig should be 0
But sig_intr appear a pulse when doing reset
Will this situation because of the unstable of reset?
BTW, we also disscuss about the possiblitiy of synchonus reset woule influence sig_intr problem,
but we are not sure if this would be the problem after synthesis or not.
- sstrell
It certainly could be because of the unstable pulse. Signal Tap can't help with capturing an issue like that. Check your timing analysis. What does your .sdc look like?
But stranger is that there is no way in your design for sig_A to ever go high. Typo in your reset process?
- WNC_HowardHuang
Thanks for your replay.
In our design, there's only have clock in .sdc file
create_clock -name CLK25M -period 40.000 -waveform { 0.000 20.000 } [get_ports {FPGA_25M}]I think there's no error with reset process because reset signal is from outside FPGA.We'll looking forward to this problem.Thanks.
- FvM
In addition, what's the reset source? In case it's asynchronous to clock, you urgently need a reset synchronizer to achieve predictable behaviour.
Frank- WNC_HowardHuang
The source of reset is from the other CHIP outside FPGA.
We guess the unstable waveform might be caused by PCB layout.
We tried to synchronus reset using shift register
Then replace original procedure reset part by higher bit of shift register
So far, the test result seem fine.
But we think the best way to solve this problem is to figure out the unstable problem of reset.
- SyafieqS
Higher bit shift register might be a good temporary workaround. But you still need to root cause from outside for unstable pulse. Afraid might cause another issue.
- SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
