sgulh's avatar
sgulh
8 years ago
pls provide me verilog code for led rotate on fpga
i have de 2 115 fpga i need led rotate verilog code
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    You can achieve it with simple ring counter and delay logic.
    For more information refer below logic or you can google it.
    //To create the frequencies needed:
    // Input clock is 25 kHz, chosen arbitrarily.
    // Formula is: (25 kHz / 100 Hz * 50% duty cycle)
    // So for 100 Hz: 25,000 / 100 * 0.5 = 125
    //operate the below logic from requried clock
     if(clr==1)
                q<=4′b1000;
     else            begin
                q[3]<=q[0];
                q[2]<=q[3];
                q[1]<=q[2];
                q[0]<=q[1];
     end
    Anand Raj Shankar
    AnandRaj_S_Intel
    Above code is not complete, you have to complete.
    1. Have you inserted clock?
    2. At what frequency your design works?
    3. What is not working in above code?
    You need to work with Modelsim first and try to understand coding.​
    // Quartus Prime Verilog Template
    // One-bit wide, N-bit long shift register
    module basic_rot_register
    	input clk, enable,
    	input sr_in,
    	output sr_out
    	// Declare the rotate register
    	reg [3:0] sr;
       reg [23:0] count=0;
    	reg clk_out=1'b0;
    	// Shift everything over, load the incoming bit
    	always @ (posedge clk_out)
    	begin
    		if (enable == 1'b1)
    			sr<=4'b1000;
    		else
    		begin
    			sr[3:1] <= sr[2:0];
    			sr[0] <= sr[3];
    		end
    	end
    	// Catch the outgoing bit
    	assign sr_out = sr;
    always @(posedge clk) begin
       count <= count + 1;
       if(count == 10000000)//5hz
       begin
          count<=0;
          clk_out <= !clk_out;
       end
    end
    endmodule
    Anand Raj Shankar
  • sgulh's avatar
    sgulh
    thanks for reply but given code not working i tried it on google but
