sgulh
8 years agopls provide me verilog code for led rotate on fpga
i have de 2 115 fpga i need led rotate verilog code
AnandRaj_S_Intel
8 years agoHi,
You can achieve it with simple ring counter and delay logic.
For more information refer below logic or you can google it.
//To create the frequencies needed:
// Input clock is 25 kHz, chosen arbitrarily.
// Formula is: (25 kHz / 100 Hz * 50% duty cycle)
// So for 100 Hz: 25,000 / 100 * 0.5 = 125
//operate the below logic from requried clock
if(clr==1)
q<=4′b1000;
else begin
q[3]<=q[0];
q[2]<=q[3];
q[1]<=q[2];
q[0]<=q[1];
endLet me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
