sgulh
8 years agopls provide me verilog code for led rotate on fpga
i have de 2 115 fpga i need led rotate verilog code
AnandRaj_S_Intel
8 years agoHi,
Above code is not complete, you have to complete.
- Have you inserted clock?
- At what frequency your design works?
- What is not working in above code?
You need to work with Modelsim first and try to understand coding.
// Quartus Prime Verilog Template
// One-bit wide, N-bit long shift register
module basic_rot_register
input clk, enable,
input sr_in,
output sr_out
// Declare the rotate register
reg [3:0] sr;
reg [23:0] count=0;
reg clk_out=1'b0;
// Shift everything over, load the incoming bit
always @ (posedge clk_out)
begin
if (enable == 1'b1)
sr<=4'b1000;
else
begin
sr[3:1] <= sr[2:0];
sr[0] <= sr[3];
end
end
// Catch the outgoing bit
assign sr_out = sr;
always @(posedge clk) begin
count <= count + 1;
if(count == 10000000)//5hz
begin
count<=0;
clk_out <= !clk_out;
end
end
endmoduleLet me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
