PLL Reconfiguration Timing Constraint
I have a question on the PLL timing constraint when working with Cyclone V Pll reconfiguration.
In my case, I have the PLL output 2 different frequency, 1 is 10MHz and the other is 300MHz. Then I have to use the reconfiguration.
Then how could I constraint the clock instead of using "derive_pll_clocks".
Thank you!
- Farabi_Altera
You may want to refer to this document: https://www.intel.cn/content/dam/altera-www/global/en_US/kdb/rd10162012_514/pll_clock_switchover_constraints_in_28nm.pdf
regards,
Farabi - Farabi_Altera
regards,
Farabi
