SKon1
6 years agoPLL Clock Forwarding
Hello, I'm using an Arria V device and I want to send an internally PLL generated clock to an output pin. What's the recommended procedure for this ? 1. Connect the output of the PLL directly to t...
SreekumarR_G_Intel
6 years agoCan I know output pin used is dedicated clock pin ? if yes then there is not need to use the ALTCLK buffer in between pin and the PLL output.
Thank you,
Sree
