Please, do not release another version of Quartus until you fix the file length problem in windows
- 4 months ago
Are you referring to the maximum file path length? If so, this is a Windows limitation.
Windows limits the combined length of a file name and its path to 260 characters. If your project path exceeds this limit, Quartus may be unable to access the required IP or design files.
Additionally, the Quartus Prime Pro 26.1 installer includes an option to enable Windows Long Path Support by default. Older installers may not provide this option.
Alternatively, you can refer to the KDB below for instructions on enabling long path support in Windows.If the issue persists after enabling long path support, could you share more details, such as the exact compilation error message or logs?
Error: Logic Generation failed to load results from Design Analysis and cannot get the list of IPs in the design | Altera Community - 353145
https://www.reddit.com/r/Windows11/comments/1knbabm/windows_file_path_limit/
Richard Tan
What are you talking about? Example of what you are seeing?
