Platform Designer UI
- 1 year ago
Thank you, Njoroge, for your valuable and constructive feedback.
We’ve taken your input into consideration, and it is planned to be incorporated into the next-generation Platform Designer.
While I don’t have visibility into the final implementation just yet, we look forward to seeing the improvements in 2026.
Hopefully, it will offer a significantly enhanced user experience.
Richard Tan
Yeah, time to go to a higher resolution screen I guess which isn't a great option, especially for a laptop. I have the same problem.
A UI refresh is still inevitable, I think. The IPs keep increasing with each release and designing using the current system is too cumbersome Some Hard Processing System IPs for example can take up the whole screen whereas a schematic approach can have blocks with connections on two sides of an IP block which in my opinion would help give a smoother design process.
