Steve-Mowbray-ENL
2 years agoPlatform Designer Instance Parameters script update real parameters in library components
So I can now set parameters in IP library components from the Instance Parameters instance script thanks to this: https://community.intel.com/t5/Intel-Quartus-Prime-Software/Platform-Designer-Instan...
ZH_Intel
2 years agoHi Steve,
Apologize for the delayed response as we encounter technical difficulty.
I believe that it should not matter which parameter is it defined as, either integer or strings as these are types of variables. It depends on the parameters that you want to modify. As long as you reach to the proper files required in the project.
Hope this answers your question.
Thank you.
ZH_Intel
