AChri1
7 years agoPlatform Designer in Quartus 18.1 Standard gives the error: Error: max10_test_ddr3.mem_if_ddr3_emif_0: 'Debugging feature set' must be set to 'No Debugging' when 'Generate SOPC Builder compatible resets' is enabled.
I am trying to connect DDR3 memory with a 24bit data bus to an FPGA 10M40DAF484C7G to implement a 16bit data bus with ECC and via the FPGA connect it via a 32bit multiplexed data/address bus to an ex...
Abe
7 years agoHi,
Can you share your design here so that we can take a look. Looks like you have to disable it in the Diagnostics tab of the EMIF controller or if you have any other diagnostic module the setting maybe in it.
