JFrye7
6 years agoPlatform Designer Import AXI Master Component: Error: Data width must be of power of two and between 8 and 4096
I created an AXI4 Master component in a ip-management project. I was then able to include it in platform designer, hook up the AXI master to other Avalon/AXI peripherals and generate the system. I th...
sstrell
6 years agoInstead of reopening the Component Editor to add your custom component to another project, either copy and paste the code and _hw.tcl file to the location of the new .qsys file or from Tools->Options add a path to point to the _hw.tcl file. I'm not sure why you're getting that particular error without seeing the system design (any errors in Messages window before trying to generate?), but there's no reason to go through Component Editor again if the component works fine in one design.
#iwork4intel
